Definitely not, please continue.Hope you're not getting bored with these lavender grey wagons but they are all different.
Here's the early coal wagon again but now fitted out with hinges et al. The next picture, when it comes, will show a completed wagon once again painted in the 'lavender grey' of the London and Brighton. Well, my version of lavender grey. The nuts, if you can see them, are all 16BA opened out to take a 1/32" rivet. The ones holding the W irons are still 16 BA but opened out and taped 14BA, a very good tip from a fellow modeller.
The styrene used, I had to order from Canada as I couldn't get the size of section of styrene in the UK. I wanted to build a number of wagons and carriages so, thought the added expense of postage worthwhile. The actual styrene is much cheaper over the pond.
I very recently bought some more from them as I wanted to use it to build the under-frame of the tender for Lion. The under-frame is made up of all sorts of sizes and I felt that styrene would be the easiest option.
No, the guides are not castings but sawn from 1/16" (I think without checking) brass with the guides riveted on behind.
They do look good.
