AndyB
Western Thunderer
Carney?...an etch supplied by Diane (can't remember her surname).
Now editing 'Model Engineer' magazine and, to many people's disappointment, no longer etching plates!
This is the next wagon on the list and I hope nobody out there is stifling a yawn. The other two pictures show how I line up and square the styrene sides to the ends during construction of the body using magnets and a machined and ground mild steel block. It works for me and is less fiddly than trying to use a corner clamp. The under frame for this wagon is in wood as I couldn't find any styrene/Evergreen strip deep enough for the solebars. When the body is finished, I shall most probably use an epoxy glue to fix it in place on the under frame. The curved tops to the ends, I am making from separate pieces as they over sail the sides. Yes, I'm sure that is how it was built originally and it took me ages to work this out from looking at the drawing.
You can edit your post if you want to remove the extras Jon, just click on 'edit' at the bottom of the post.not sure how I managed to up load the pictures twice![]()
Yes, styrene is so easy to use but not to file. I've been making the curved ends for the above wagon and it doesn't like to be filed or at least draw filed unless it's an old file that's being used.
I looked at the prices for the lime strips and thought them reasonable until I looked at the sheet! Think I'll stay with styrene.
But the prices of the thicker sheets certainly would put a dent in the wallet. And postal prices might make a difference as well. I've had strip from Cornwall before and the price for postage was quite reasonable. But that might have been for materials that would go in a 5cm diameter postal tube. 10cm wide sheet might be another matter altogether.Bending styrene strip, 4 x 3mm, isn't as easy as I imagined. Tried immersing in boiling water and even used the hair dryer while it was in the former but no doing. So, it's back to the drawing board and as Scarlett once said, Tomorrow's always another day. I think the strip is a bit on the heavy side but that's the size it needs to be. I was going to saw it from a 3mm sheet but the thought of trying to clean up the cut edges put me off that idea
give them a go.
This is the first former that I made and the curve was wrong. I made another former with a third 'block' positioned at the top of the it. But, I thought to myself that I would make it a little smaller to allow for spring back, WRONG! There was no spring back and the styrene cam out perfectly if a little small. Instead of making another former, which I should have done, I worked the styrene by had until I got it right and then fixed it in place on the wagon. The former worked very well and the result would have been perfect if I had made it the correct size. My oven doesn't go down to 100 degrees so, I cooked it at 150 C for twenty minutes without harm to styrene or MDF former. If I'd only made the former the correct size.....
As you've found out, there should be no spring back if it has set properly in its new shape. As I said before, my test when taking the piece out of the oven was to release the clamps and see if the part sprung back by any amount. If it did, it was re-clamped and poked back in the oven for a bit more treatment.
