mickoo
Well that was an interesting exercise
adding the Hachette body to the frames.
Side on the body follows the footplate much better, despite being raised off by the lugs (to be removed) under the body.
But nose on something is really not right here.
The nose is just too thin and doesn't match the footplate at all, curses
A quick rummage finds the relevant drawing and a quick measure across the footplate at this joint reveals it should be 56.7 mm wide, grabbing the digital measuring stick finds that the Hachette body is 55.3 mm wide which isn't too far out in the grand scheme of things and workable with... a trim of 0.2 on the footplate and an overlay on the side of the buffer casing would solve that. However, the DJH is a whopping double fat burger 59.5 mm wide and of course that's what the etches were measured off.
Basically I need to do two sets of footplate etches, one for the more accurate Hachette and I suspect Finney and retain the remaining ones on this sheet for the DJH shells
MD
adding the Hachette body to the frames.Side on the body follows the footplate much better, despite being raised off by the lugs (to be removed) under the body.
MD
- lutely, I've crossed referenced all my photos and drawings with the A4 and give or take an inch (thickness of a line on a GA) or so the front end is 99% copy of the A4 as far as I can tell.
