John Walker
Active Member
I joined the Scale 7 Group at Telford having volunteered to build the Slaters MR/LMS Kirtley 0-6-0 Goods (Johnson) 7L007 (Slater's Plastikard - MR/LMS Kirtley 0-6-0 Goods (Johnson)) for HMRS to run on Dewsbury Goods.
I usually model in O gauge (https://sites.google.com/site/ogaugeinthegarden/home) and 3mm finescale 14.2 (Swanage in 3mm).
As a starter I have changed the wheels on my late Dad’s J71 using those available from the Scale 7 group. That was straightforward enough.
The Kirtley Goods looks more of a challenge. For a start there is no clearance over Scale 7 wheels between the splashers, assuming the same face to face dimension as with the J71 wheels. However I think there is scope for moving the splashers out a bit.
The kit includes Slaters wheels and extended axles. The extended axles and wheel centres have a matching taper. I am hoping that Colin Dowling can reprofile these wheels for Scale 7.
David White has been very helpful and he is sending me Scale 7 axles to replace the O gauge ones in the kit.
There is a problem with the outside cranks included in the kit as shown below.
The plastic shoulder is too big too run in the outside axleboxes. I removed the plastic shoulder using a piercing saw to expose the brass insert. This turned out to be like a three-penny bit so I mounted the crank on its axle in the Unimat and turned the brass shoulder to remove the flats. It is a bit loose in the hornblock now but it doesn’t really matter as it isn’t a running surface. I have also substituted a countersunk screw for the crankpin as the cheesehead supplied fouls the hornguides. All that looks good now. If I have a problem due to the need for sideplay I could turn a parallel bush to fit behind the insert.
While waiting for the replacement axles and a response from Colin I have started work on the tender. My intention is to find out how much sideplay is needed to run on Dewsbury Goods which we think has a minimum radius of 6 feet. Then I will have to decide whether to increase the width across the inside frames of loco and tender. This will also give me the information needed to revisit the clearance between the splashers.
I would be interested to know if anybody else has built this kit.
