Simon
Flying Squad
A few more steps today, starting with glazing the windows with slide mount glass suitably cut down with a glass cutter on the bench. This didn't go completely smoothly but I ended up with useable pieces and little waste. They were all epoxied in place between the window bars and inside face of the body sides.
I then made a retaining chain for the vacuum pipe using some ancient jewellery chain and a loop of brass wire, very fiddly but it worked well, both vac and brake pipes can be unhooked and connected up to another vehicle, as if..
I soldered the pipe fittings to the body using detailing solder.
I then took the plunge and epoxied the roof to the body, basically applying the resin to the ends and the two sprung lugs, and then up-ending the whole so that the epoxy ran down the ends and on to the inside of the roof.
A few things crossed off the list, still left to do brake levers and label clips plus all the door furniture. Then forged ends on the handrails and lots of bolt heads. Roof ventilators (in stock) and rainstrips to go on. And the SBR over the roof "canvass" needs to lose its tack, which it will in time.
I am beginning to quite like it
