OzzyO
Western Thunderer
Hello Heather,
do you plan to move the supports that are in the coal bunker? As the front one should be right at the back of the top of the tender front coal plate.
For the tender compensation units this is how I tend to do it. Using two dummy axles turned to 29.2mm they set the bearings positions, then a length of 3mm tube that will form the pivot,
After this the pivot tube is cut in the middle using a fine saw blade (this gives a bit of play) it also lets the two axles move independently. To make sure that the pivot pin rod can't come out of the frames I just solder one end of the rod,
ATB
OzzyO.
ATB
OzzyO.
