jonte
Western Thunderer
Hi Jon,
No, using the full sweep of the servo was not required.
The 3 "buttons" are variable potentiometers that contain a screw adjuster, two of which set the end points of the servo sweep and the 3rd sets the speed. Getting the end point for the signal arm horizontal is the worst part, the 45 degree angle is easier as there's some tolerance, in that as long as it looks ok, it's good enough and the speed is a matter of choice. Remembering which pot does what is the worst part.
I have also used the servo4's which are easier to set up with servo set. Once set up they are great.
Thanks, Phil
Even I can understand that
Jon
