Greengiant
Western Thunderer
As a bit of light relief from the engine shed, I made a start on a signal box, this is a mash up of the two boxes on the Bredgar & Wormshill Light Railway, both of which I have operated. I now regret this approach and wish I had modelled each box as its own entity, needing a number of signal boxes for the railway this would have been a better course of action. I have also found there is more enjoyment in the challenge of modelling an actual building, it also removes the need to design something.
On with the project, this is the box at Warren Wood...
The box at Stony Shaw, that is me in the doorway...
My drawings to work out all the sizes.
Some of the parts drawn and embossed.
The front wall cut out from 5mm PVC Foamex.
Some parts for the steps and verandah cut from 3mm PVC Foamex, which will later have 2mm laminated both sides in places to give a thicker timber look to the posts.
The chimney coming together, made from 5mm PVC Foamex.
Here can be seen some of the laminated stairs sides, the roof trusses, the rear of the chimney, the chimney top and the brick edged concrete base the stairs and veranda will sit on.
Martin
Martin
