LarryG
Western Thunderer
A good pal of mine wanted a GWR Dining Car. A bit of research unearthed Comet etched sides from Wizard Models. The H33 looked a good option so I also bought two Hornby bow-end corridor coaches. One as a donor for chassis, ends and roof and the other is for my layout. The deciding factor were the GWR 7' bogies. Had I built the whole coach in metal, I would have had to fit whitemetal bogies (too heavy)...
As usual, the sides were slotted to take my standard lower door hinges. The sides were also shortened a tad to fit the Hornby roof & ends. Then a stip of brass was soldered edge-on inside the coach side at the very top. It acts as a strenthener and provide a larger surface area for glue...
The sides were cut away and the roof drilled to take new shell vents (after the Hornby ones had been cut off and the roof filed smooth)...
Construction has reached the stage where it's all gluing from now on...
To be continued...
To be continued...
