Greengiant
Western Thunderer
Baseboard construction continues and ground form starts to make an appearance.
Final piece of scenic section trackbed now installed, four of the six scenic boards are in this photograph. This view is from the RotaYard boards.
Using a lot of this stuff to stick down the foam.
Gorilla glue expands to three to four times its volume and also acts as a filler that can be carved, sanded and painted. Sticks like the proverbial to a blanket!
What you must remember to do is make sure location dowel holes are covered at the rear!
Some of the boards with foam waiting to be stuck down.
Trunking for the wiring is also installed along with aluminium tube to hold the point rodding.
Very therapeutic shaping this with a Surform, makes it very easy, sometimes too easy.
The final scenic board now has the foam cut ready to be glued in place.
Martin
Martin
