Jim smith-wright
Western Thunderer
Hi Martin
Thanks for your thoughts (stir the hornets nest? odd term to use). Interesting that you say about cutting back the 'cobblestones' as I did this more on these buildings than the lamp block on new street (the only real brick building on there so far.) I wonder if the gloss re-exagerates it?
The corners of the big building are indeed less than perfect but because I had to build it in situe due to the 2 interiors I didn't have much option. There's still more ironwork to do yet so I might have a look at the main corner. I'm not happy with one of the bridge walls either so I'm going to go back to it. Things like this are harder to see when it's dark! Lol.
The layout was never intended to go out into the public, It was only supposed to be a plaything. I had to do quite a bit of work to replace the sides etc to make it robust enough.
I don't think I've used any common bond brickwork. Do you mean garden wall bond? It was from south eastern finecast, I think they've discontinued it.
Jim
Jim
