SimonT
I have been pecking away at the 8750 and realised that a lot of work has passed without comment. I have just started final cleaning up of the upper bits so I will try to describe the changes made since I last posted. So, firstly....
The main changes from the kit design have been replacing the white metal feed pipes with copper wire and then acquiring bits of pieces to allow me to replicate the desired loco. Luckily all the bits were available from either Hobby Horse or LG. So the differences are clip lid tank fillers, a different pattern of injector where the water valve is immediately under the tank, moving the spare lamp irons to alongside the fireman's side injector. I also opted to fit the Hobby Horse brass chimney.
Below the footplate I have fitted the correct plate work for the brake hangers. The brakes are printed and include the correct mounting bracket at the top. This slides over the normal mounting pins and butts up against the plate. Crossbars are micro tube with 14BA studding soldered in so that everything can be held together with 14BA nuts. These appear to be the correct scale size! I am holding on pick ups to see how Ian's design are put together so that I can fit a set as I know his locos run beautifully.
Since I took the photo the loco has had a coat of Halfords etch primer and then a coat of conventional filler primer. Now to break out the Christmas pressie airbush to make with dirty black.
Simon
The main changes from the kit design have been replacing the white metal feed pipes with copper wire and then acquiring bits of pieces to allow me to replicate the desired loco. Luckily all the bits were available from either Hobby Horse or LG. So the differences are clip lid tank fillers, a different pattern of injector where the water valve is immediately under the tank, moving the spare lamp irons to alongside the fireman's side injector. I also opted to fit the Hobby Horse brass chimney.Below the footplate I have fitted the correct plate work for the brake hangers. The brakes are printed and include the correct mounting bracket at the top. This slides over the normal mounting pins and butts up against the plate. Crossbars are micro tube with 14BA studding soldered in so that everything can be held together with 14BA nuts. These appear to be the correct scale size! I am holding on pick ups to see how Ian's design are put together so that I can fit a set as I know his locos run beautifully.
Simon
