mickoo
Richard,
I'm just using a simple (ground for brass so it does not dig too deep) lathe tool as opposed to the one ground for Slaters steel rims. The nut does hold the work perfectly well......so far. There's enough 'grip' between the holder and wheel face to allow you to cut 2-3 thou off each pass but you do need to make a small dish in the centre of the holder to take the Heljan wheel boss which sticks out by a few thou.
No soft jaws at all, wouldn't even know what they were if they bit me on the ankle, soft jaws for a vice, yes, but a lathe?
It's all very un S7 to be honest, the correct way would be to use a form tool to get the correct wheel profile but I work on the principle that if it rolls through Love Lane then that's good enough for me
All I do is take 15 thou off the back of wheel, then I take 15 thou off the flange and just round the flange off with a file (I tell everyone it's a special S7 file...but shussss it isn't really
) and then some fine abrasive paper, S7 of course, y'all can probably guess right now I don't take it too seriously LOL.
I do not touch the tyre cone or angle or rim face, just the back and the rim edge, all very school boy I know but looks the part (except to those with micrometer eyes) and works very well so far on both the Class 26, A1 tender, Fowler 4T and Std 5
Hope that helps
Mick
) and then some fine abrasive paper, S7 of course, y'all can probably guess right now I don't take it too seriously LOL.I do not touch the tyre cone or angle or rim face, just the back and the rim edge, all very school boy I know but looks the part (except to those with micrometer eyes) and works very well so far on both the Class 26, A1 tender, Fowler 4T and Std 5
Hope that helps
Mick
) and need refining even for F/S let alone S7.
) . This is all done in the conventional set of jaws all held up tight with a revolving center in the tail stock.
I haven't seen any issues with mine without coning so I'll let sleeping dogs lie, but will see to it on the next model
but the coning doesn't look 100% consistant over all eight wheels.
