Ok moving on, the revised etches came back for the bogie, Cartazzi and trailing truck and I've been test building them and working up the instruction photos, so nice new cutting mat and lots of light for better photography.
There wasn't much changed on the bogie, a relaxing of the side control pressure by moving the webs internally and the addition of the BR angle across the front instead of the LNER tie rod.
The W1 was not fitted with AWS as far as I can ascertain, so no need for further appendages in this area. I did also add the weather shield (optional) over the real side control springs, I've no proof this was ever fitted.
It was fitted to A3's and A4's during their life time, so logic dictates it 'may' have been fitted to the W1, so best to add it to the etches in case new info ever surfaces.
Moving rearward the Cartazzi has had a full make over and is now a sprung radial truck.
The two springs provided suspension whilst allowing the assembly to slide within the inner horn guides. The washers are not fixed, but slide up and down the pegs under the spring pressure and are there to aid the spring sliding left and right.
An extra plate was dropped into the bottom of the inner horn guides with two angled slots for the pegs and the slots limit side play (more on side play later).
Radial Cartazzi assembly installed.
From the low angle rear view you can see the two small washers to assist the sliding of the springs and the pegs going through the slots which follow the same arc as the curved front and rear faces.
Side play, currently the wheels are not fully pressed home so there is an excessive gap between them and the assembly. When fully pressed home there will still be a small gap and this could form part of the side play, the axle being free to slide without the Cartazzi assembly moving. That alone should give about 2.0 mm of play, on top of that the slots give 3.0mm play. You can limit the free side play by adding washers so that the slots give the maximum allowable side play, either way, without washers the axle end should still clear the inside face of the outer frames easily.
One other option is to develop some sort of side control springing as well, but I'm in two minds if it would add any benefit to an engine that primarily goes forward. With side control springs then removing the washers allows some free movement for small track irregularities or shallow curves, but then as it tightens the assembly starts to move which having the side control springs on generates some extra force.
It'd be a lot of work and probably not worth it, but for say an N2 or N7 then yes it'd certainly benefit from some side control pressure.
Onward with the trailing truck, which again has had a make over and taken on board several suggestions and comments from earlier and elsewhere
MD
